I recently built a Genera phono stage and have since been exploring the mysteries of cartridge loading. Once it had been burned in, I can confirm that the standard 220pF capacitance gives an excellent sound with a moving magnet cartridge (Sontra 500EX), running either into a Rogers HG88 or HiFi World KEL84 amplifier. However my normal cartridge is a Denon DL103 through a HiFi News Blackhead stepup transformer (10x) and this has proved more problematic. I have two DL103s: one with the standard stylus and one with an Expert Stylus Paratrace stylus and lightweight sapphire cantilever. With the standard stylus 100pF capacitance sounded good but a little edgy at the top. At 220pF the sound balance was too bright;
it reduced the edginess but lost crispness as well. 150pF gave a reasonable but not perfect compromise. However with the Paratrace stylus there were problems. At first, tracking was great, detail was great but there was a false brightness on some records and a spittiness and edginess. Also, although it tracked perfectly, it sounded strained and downright unpleasant on some records. The first stage of the solution was to play around with alignment and tracking weight to get the best basic sound out of the cartridge (line contact styli are very fussy compared with a standard spherical). However although this got rid of the spittiness, some records still sounded terribly strained and unpleasant. I knew that CD sounded fine through the amplifier, so the problem had to be something to do with the Denon and the Genera. Having run out of other options, I tried adding a parallel 500 ohms on the 'cartridge' side of the stepup transformer, in order to reduce the input resistance seen by the cartridge from 47k/100 = 470 ohms to 240 ohms. The result was miraculous: suddenly the glare and strain disappeared, leaving only sweetness and light. I appreciate that it is probably not common to feed a Genera with a low output moving coil and stepup transformer and the Denon DL103 is notorious for its setup and loading foibles. However anyone else who runs into similar problems may find the above experience helpful. However what was going on technically? I previously used the Denon DL103 Paratrace and stepup transformer to feed the Rogers HG88 phono input without any problems, so there was nothing wrong with the Paratrace stylus. Also why was the Paratrace DL103 so much worse than the DL103 with a standard stylus? I can only assume that there was something different about the Paratrace DL103's output which was causing trouble - and this was somehow eliminated by reducing the input impedance across the DL103. The main effects of lowering the resistance fed by a cartridge are to increase high frequency damping and also (working in series with the cartridge internal inductance) a roll off of output at high frequencies. Could it be that, compared with the standard DL103, the lightweight Paratrace stylus was generating more output at supersonic frequencies, e.g. due to record cutter ringing, and either this was upsetting the Genera itself or else it was being passed on faithfully by the Genera and upsetting the main amplifier? If so did the lower resistance solve the problem by reducing the cartridge's supersonic output to a level that did not cause trouble? Any thoughts? Alasdair
