Case for old Solo
Category: DIY AUDIO
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1420
Printed Date: 27 Mar 2026 at 2:30am
Topic: Case for old Solo
Posted By: John225
Subject: Case for old Solo
Date Posted: 07 May 2012 at 12:28pm
I'm thinking about upgrading to Ultra Linear but would like a case to put my old Solo (2007) in.
So...anyone got any ideas??  I gather there are some from rapid which work ok if you drill them, anyone tried anything particular which worked well?
Even better has anyone got an old Solo case I could buy off them?  Or maybe Graham has some seconds knocking around somewhere...Big smile
Thanks,
J
Posted By: jamescodway
Date Posted: 07 May 2012 at 5:22pm
Hello... there's some stuff here... its absolutely do-able if you have some basic tools and a(nother) power supply Smile
http://www.gspaudio-community.activeboards.net/what-have-you-done-with-your-old-solo-after-upgrad_topic1108.html - http://www.gspaudio-community.activeboards.net/what-have-you-done-with-your-old-solo-after-upgrad_topic1108.html
Best
James
Voyager - HD25
Posted By: John225
Date Posted: 07 May 2012 at 5:57pm
Best
James
Ooooo thanks, that thread is just what I needed.
Thanks,
John
