GS interconnects with other label equipment
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=141
Topic: GS interconnects with other label equipment
Posted By: Petri
Subject: GS interconnects with other label equipment
Date Posted: 23 Apr 2008 at 5:13pm
I'd like to try GS interconnects with my turntable system. It has Transfiguration spirit mk3 cartridge with regular RB250 arm and Clearaudio Balance RIAA. Pre amplifier is Copland CTA-301 mkII tube amp.
I have used Audiquest Ruby, but it's sound is little "muddy", now i have Nordost RedDawn but i had so good experiences with GS Revelation with my earlier 10X5 cartridge that would like give a shot to either of your interconnects. Do you think it would be good match ?
Can those interconnects be used in two meter lenghts ? Would be easier to place turntable and amplifiers further from speakers.
Thanks
Petri
Date Posted: 23 Apr 2008 at 8:07pm
Hi Petri, as the RB cable is fixed I assume you don't mean from turntable to preamp?
Our phono to phono cables (primarily the Cusat50, but also the Agsat90) can be used with all phono socketed equipment.
They are designed to well and truly keep out radio interference - this is important as radio interference can give rise to an over-bright sound. If that is what is needed, our silver-loaded Agsat90 should deliver the "goods".
Both types are directional, which means they give a more together performance one way round than the other (tried by us in "double blind tests"). Don't ask me how this works - I'm just a simple electronics designer Wink
The Agsat90 can only be done in 1m lengths because that's as far as we can feed the "soft" silver wire reliably.
The Cusat50 is available in 1, 1.5, 2, 3 and 4.5m lengths.
Please see http://www.gspaudio.co.uk/Interconnects/cusat50.htm - http://www.gspaudio.co.uk/Interconnects/cusat50.htm for further product details, and http://www.audiocontrol.co.uk/graham_slee/cusat.htm - http://www.audiocontrol.co.uk/graham_slee/cusat.htm to buy direct (the plugs in the picture are right at the first link but wrong on our shop site)
Posted By: Petri
Date Posted: 23 Apr 2008 at 8:30pm
Thanks for the reply, yes i ment from RIAA to pre amp.
