Voyager instruction diagram?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1250
Printed Date: 27 Mar 2026 at 4:00am
Topic: Voyager instruction diagram?
Posted By: gbr2004uk
Subject: Voyager instruction diagram?
Date Posted: 27 Nov 2011 at 6:03pm
Hi.  Confession first, I haven't used my Voyager for several months (been doing photography / Photoshop) and can't find what I thought I had, namely a diagram to remind me what the little white slider thingies on each side are ...  presumably 'flat' versus the other thing whose name I can't remember right now tho' I know what it does.  I want to get back to some serious listening again.   I've looked around the site and can't find a Manual or instructions (tho it's so basically simple to use, please don't laugh, I'm doing that myself ...)
Thanks in advance for help.
Brian
Milton Keynes, UK
Date Posted: 27 Nov 2011 at 6:07pm
The functions of the slide switches are printed on the metal label.
Date Posted: 28 Nov 2011 at 12:37am
Graham, thanks but I don't have any metal label, at least not on the Voyager instrument itself.
Date Posted: 28 Nov 2011 at 7:12am
Hi Brian, hope this helps.
The three way switch selects the power source: 12/24V in from adjacent socket at that end, USB power in middle, 9V internal battery is position at headphone socket end.
The two way switch turns the Contour on and off. It is off ("flat") with switch closest to the mini USB socket, on ("Contour") with switch at headphone socket end.
Happy listening.
Date Posted: 28 Nov 2011 at 10:15am
Are you saying your Voyager has had its top plate ripped off?
It should look like this...
The control information is printed in the grey curved stripe.
