To upgrade the Headphone cable?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1240
Printed Date: 26 Mar 2026 at 11:13pm
Topic: To upgrade the Headphone cable?
Posted By: Paul P
Subject: To upgrade the Headphone cable?
Date Posted: 13 Nov 2011 at 8:32am
Hello , I own Sennheiser HD650 Headphones .I was reading on some site that it is possible to buy upgraded Headphone cables for these , has anyone experienced this or could advise .Thanks.
Posted By: mrarroyo
Date Posted: 13 Nov 2011 at 2:32pm
I have compared over 13-15 aftermarket cables ranging from $125 to over $500 using a Sennheiser HD600. To my ears the best sounding one wash $195 but the $125 was almost as good and  you really had to listen long and hard to hear the difference. So I bought the $125 from Headphile using their "blacksilver" wire.
Note that what is good for me may not be for you, at the time I was looking to improve the treble extension of the HD600 and the silver cable did it for me. However not only are cables expensive but what may work in one system may not work in another.
As an alternative to a cable may I suggest you remove the foam in front of the driver and replace it with a ladies stocking stretched over the driver to protect it. You may be surprised by the change (or not).
Posted By: Paul P
Date Posted: 13 Nov 2011 at 2:52pm
Thanks for that.Smile
Posted By: Suggs
Date Posted: 14 Nov 2011 at 10:06am
Hi
I upgraded ages ago to a Cardas cable and was really impressed by the difference on both the 600's and 650's. Although this isn't a cheap option, in my opinion it is very worthwhile and makes a great set of phones even better. The only downside (other than price) is that the cable is less flexible. There are usually good condition second hand ones around on eBay..
