PSU 1 Burn In ?
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1208
Topic: PSU 1 Burn In ?
Posted By: Paul P
Subject: PSU 1 Burn In ?
Date Posted: 07 Oct 2011 at 4:27am
Hello , does anyone know if the PSU 1 need's time to Burn In . Or is it good to go straight from the box? Thanks.
Date Posted: 07 Oct 2011 at 9:15am
An IEC60950 safety test is satisfied after 72 hours (3 days) at maximum load. At this time the transformer is assessed to have reached it's optimum working condition. Therefore the planet's electrical safety law makers also recognise burn-in.
Note this is at maximum load. Therefore when running at a more relaxed loading the time to reach an optimum state is extended. By how much? We could assume it is the inverse of maximum load divided by the actual load. If powering a Solo with no signal, the load will be in the order of a tenth of maximum, which translates to 30 days by IEC reckoning.
(IEC: International Electro-technical Commission)
Posted By: mrarroyo
Date Posted: 07 Oct 2011 at 11:23am
Hi Paul, you already have an answer from Graham to your first question better than any of us could give. Big smile As far a "good to go" YES, you can start using it and enjoying it. Wink
