Genera Kit Phono Amp
Forum Name: Write A Review
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=1028
Printed Date: 26 Mar 2026 at 10:54pm
Topic: Genera Kit Phono Amp
Posted By: Steebo123
Subject: Genera Kit Phono Amp
Date Posted: 22 Dec 2010 at 4:27pm
Hi
I just want to say a word of praise for my newly built Genera kit phono amp.
I am listening to it right now with an Audionote TT1/RB250/Denon DL160, into a humble NAD C326BEE and MS Aviano 1's and can't believe how good is sounds.
Over the years (pre divorce 10 years ago!) I have owned a LP12 and a Gyrodeck with far more exotic cartridges and amplifiers. Post divorce I have turned to various aspects of DIY including kit valve amps.
The Genera is simple to built, uses reasonably priced, basic components, and sounds great. The DL160 is a marriage married in heaven, although I have good results also from a Goldring 1042. It does have potential for using "boutique" components, but, apart from a power supply upgrade, I can't see why you would need to do so.
Great job Graham and thanks!
