New Posts New Posts RSS Feed - POWER AMP WITHOUT PREAMP
FAT2BIKER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FAT2BIKER Quote  Post ReplyReply Direct Link To This Post Topic: POWER AMP WITHOUT PREAMP
    Posted: 07 Sep 2015 at 8:08am
Morning all
Hope I have put this in the correct section.
Can you run this setup without a preamp, turntable, phono stage, propius (2)
or do you need the preamp to split the signal into + & - .
Sorry if this sounds daft but here comes another one.
Rega planar2 with exact cartridge or rp6 with carbon cartridge which would sound the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Firth Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 8:48am
The Proprius has a volume control.
You can connect a source directly to a Proprius if you want to, and yes you need 2 of the Proprius to play stereo.
On the RP front, the RP6 has a better tonearm, and it has a proper external PSU. It's altogether better made than the RP2 was.
It should perform better than the RP2, even with a less expensive cartridge hanging off the end of the arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FAT2BIKER Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 1:29pm
Thanks once again Chris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 1:05am
The new Accession phono preamp has an output level control (volume control) on output 2 which can be used to control a power amp.
The Proprius can be used single ended by taking the signal to pin 2 of an XLR and shield to pin 1. The unused pin 3 can be connected to pin 1 or left open. When preamped by the Accession the Proprius volume controls can be parked up full, or vary one slightly if stereo balance needs tweaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 11:27pm
Yes to the OP. I connected my DAC directly to the loan Proprius amps and used their volumes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FAT2BIKER Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 8:44pm
Thanks for the replies Chris and Jon.
Mr Slee Sir went right over my head i am not up on elecitronics, but thanks for the reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 2:57pm
Dave,
 Graham is describing a "single ended to balanced XLR" cable.
It would have a RCA on one end and XLR on the other ( RCA TO XLR ).
This works great on the input to the Proprius amps.
Here to help,
