New Posts New Posts RSS Feed - Phono stage for a Roksan K2(?)
Gareth Jones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gareth Jones Quote  Post ReplyReply Direct Link To This Post Topic: Phono stage for a Roksan K2(?)
    Posted: 15 Sep 2023 at 11:39am
Hi all, I currently run a Roksan K2 integrated and K2 power amp, bi-amping Monitor Audio Gold 300's. As source I'm using an old Planar 3 ('S' shape tone arm) with a Goldring 10-40 (MM) cartridge. Upgrades to turntable and then amps are some way off due to funds and other expensive hobbies.... so in the mean time was wondering if I were to add a Graham Slee phono stage, would there be a noticeable improvement to my sound- I listen to a variety although a bias towards jazz of the late 50's, 'avant garde' e.g. Stockhausen and occasionally some bossanova. Your thoughts would be most welcome.
Edited by Gareth Jones - 15 Sep 2023 at 1:54pm
Mikeh View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikeh Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 1:41pm
From my experience, I couldn't believe the improvement going to a GS external phono stage. At that time I had a Rega Planar 1 ('90s vintage), Nagaoka cartridge and Cambridge amp.  A trial of the Reflex M had me sold but eventually went foe an Accession for the extra facilities.  The forum members trial is well worth using to find out what is best for you.
Technics sl1210gr with Victor U-2
Cambridge Audio CXC CD player
Lindemann Limetree Bridge streamer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gareth Jones Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 1:55pm
Many thanks for the reply, I'll certainly look into an external- just got to read through all the variants.
patientot View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote patientot Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 6:02pm
Gareth, how many hours does your 1040 stylus have on it? Goldring still make the 1000 series cartridges (the 1040 was replaced by the 1042) and any of those replacement styli IIRC, should fit a 1040 cartridge body.
If you do decide to go for the loan program and try out one of the GS phonos, I would make sure your stylus is reasonably fresh and not worn out. If you're not sure about the hours on it, I'd get a new one even if it "sounds okay" just to be absolutely sure.
RE: which phono stage to choose that depends on your budget and what features you might want/need. You would need to plug it into one of the line inputs of your integrated amp.
Reflex M + PSU-1 used with AT150-40ML, AT VM95ML, Stanton 680mkII + Ogura, and Shure M35X cartridges.
Post Options Post Options   Thanks (2) Thanks(2)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 8:03am
I went with a Reflex M with my Roksan Kandy LIII and Goldring 1042. The difference was astounding.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gareth Jones Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 9:39am
Thanks for the reply my stylus (& cartridge) have less than 100hrs on.
Post Options Post Options   Thanks (1) Thanks(1)   Quote patientot Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 6:42pm
Okay good. Sounds like you are good to go for the loan program then. I can confirm the Reflex M works well with Goldring 1000 series cartridges, even though I don't have my Goldring 1042 anymore.
This page was generated in 0.219 seconds.
