New Posts New Posts RSS Feed - How much difference with Cusat50?
John225 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John225 Quote  Post ReplyReply Direct Link To This Post Topic: How much difference with Cusat50?
    Posted: 12 May 2012 at 7:01pm
What are the differences when using this cable with the Solo amps compared to a standard cable.  Not sure whether to go for this cable just yet (although I would like to one day).  Is the sound difference very noticable?  I know one reviewer said it really changed their whole system, any others had this experience?
I have Sennhieser HD650s with and getting Solo UL...so, Cusat or not?!
Thanks.
Frostg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frostg Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:29pm
I can't tell you how it compares to anything else, but I can tell you I have the cusat50 connecting my reflex' M and Solo UL diamond edition and it sounds fantastic, I would not think anything could better it. But I know we all hear differently. But a big big vote from me.
Ps I have sen 250II as cans
Edited by Frostg - 12 May 2012 at 11:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote John225 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:23am
Hmmmm ok, thanks...don't tempt me Wink...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frostg Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:38am
John, but this forum is all about temptation! Of the musical kind that is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John225 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 1:43pm
I know, I know, thats the trouble!  I need a shrink, I'm addicted to GSP Tongue.  Guess I'll just have to get it then LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frostg Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 1:58pm
Me to, GSP and vinyl! There is no hope for some of us. so yes you might as well give in to the temptation! You know you will only be able to put it off so long. Think of all that agony and justifying to yourself you don't have to go through once you have made the choice to buy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John225 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 7:32pm
Yes it's very sad for people like us...due to my addiction I have had to cut down on food so I can afford more GS stuff LOL.
