New Posts New Posts RSS Feed - Home Trial - Initial Impressions
Pwog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pwog Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 3:15am
Originally posted by Pwog Pwog wrote:
A note to Graham: The home audition program is brilliant! Thank you for offering it. This has been my best audio shopping/listening experience ever! To be able to listen to a component on the system that I listen to, in the room I listen to it in, as I said, is BRILLIANT!!! Thank you, Sir.
If you've had the best listening experience ever then I've been doing my job right.
A tip regarding comparisons: as you know the Reflex M by now, stop listening with it and spend the rest of the time with the Accession bar a few hours. Then, swap back to the Reflex M and have a few hours with it. I think you will then know which is the way to go.
Thanks Graham. I was wondering, the recommended load capacitance for my cartridge is 150 - 300 pF. I don’t know about my tone arm/ arm cable. How would you go about figuring the dip switch settings?
Paul
Acoustic Research ES-1, Ortofon 2M Bronze, Ayre C-5xemp disc player, Dynaco SCA-35 (updated), Dynaco ST-70 (updated and modified), Revel performa M20, Accession M, CuSat 50 interconnects
Telling it as it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 8:21am
DIP: 100 pF.
Usually the arm wiring + arm cable contributes another 100 pF.
This will match that of the Reflex M set-up.
Pwog View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pwog Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 12:30pm
Thanks Graham! You were spot on with your suggestion. After listening (and loving) the Reflex M I switched to the Accession and listened for a couple hours. I then switched back and played the same music through the Reflex.
The Accession wins! I heard the difference almost immediately! I heard more space around individual instruments and vocals with a more refined ability to hear where the instruments were positioned within the sound stage.
What impressed me the most was the difference in the clarity and tonality of individual instruments in the music. I guess I would say uncolored, to borrow a term used by audio reviewers; more natural. They sounded like they're supposed to sound.
When I first started to compare the Reflex with the Accession, I didn't think the Accession would sound better than the Reflex in my system, but I was wrong. I have never been more satisfied with the sound coming through my system, as it was playing through the Accession.
I would like to thank Bruce Kohl for facilitating my loaner experience and, of course Graham for allowing the loaner program to exist.
Paul
RichW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 1:08pm
Your description of the Accession's particular strengths is spot on Paul. Smile
Edited by RichW - 18 Jul 2019 at 1:12pm
Elevator, Accession, Majestic, Reflex M, Solo ULDE, CuSat & Lautus.
Pwog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pwog Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 1:25pm
Thanks Rich! I was wondering if people would be able to pick up what I was putting down. I find it a challenge to put what I'm hearing into words.
Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 3:07pm
yes spot on with me too. You can only use words to describe what YOU hear albeit we appear to be all hearing the same things but with different words. There is no right or wrong answer but naturalness is a key aspect and something I always value for in any component or change.
Good luck with your purchase!
Edited by Richardl60 - 18 Jul 2019 at 3:08pm
The Source turntable, Audiomods V micrometer, Dynavector XX2-2, Accession M, Elevator, Leema Antila 2Seco CD player, TDL studio 1.
Pwog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pwog Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 11:32pm
Thanks Richard. I’ll be placing my order soon. Can’t wait, as now that I’ve returned my loaners, my vinyl just doesn’t sound as good.Cry
Paul
