Help needed: Configuring 78rpm cartridge |
Post Reply | Page 12> |
shashirao
Senior Member Joined: 04 Apr 2015 Location: Minneapolis Status: Offline Points: 156 |
Posted: 06 Jun 2017 at 7:22pm |
Hi,
I am planning to digitize my 78rpm collection. I have purchased the Ortofon 2m 78 Phono Cartridge. Set it up on my P******t Xtension turntable. Configured Elevator Exp at 47 ohms (left switch all the way down, right switch all the way up) and Accession is set to English EQ (found it a bit clear than RIAA). My recorder input level is set at 0db. However the vocals still sound very subdued. Compared to LP vinyl, the sound is also flat, echoey and lacklustre. Is that an issue with 78rpm pressings? Or is there further tweaks needed to my Elevator/Accession combo to improve? Here are the cartridge details: Technical data / Specifications Thanks in advance |
BackinBlack
I don't know if there is an error, but you say you've set the Elevator to 47 Ohms, whereas the Ortofon spec says 47K Ohms, which should be both switches in centre position.
Ian |
Chris Firth
Moderator Group Joined: 16 May 2013 Location: Rossendale, UK Status: Offline Points: 1533 |
The bit I've highlighted suggests that all you need to do is remove the Elevator from the signal path. Edit - Ian got in before me. Edited by Chris Firth - 06 Jun 2017 at 7:46pm |
BackinBlack
Oops, yes, no need for the Elevator really the 2M 78 is a MM cartridge.
shashirao
wow...that was easy...and you guys were quick with the response - many thanks.
Removed the Elevator from the chain and the sound has opened up to its full potential. In fact I had to reduce the input volume to -4db to prevent clipping. However now I can also hear the crackle/noise of the actual needle going against the groove - dust or tracking noise. This was subdued/removed when the Elevator was present in the chain, but I am assuming I also lost out on some sound. Anything I can do with the Accession CAP LOAD settings in the back? Currently they are set to factory settings. Thanks again Shashi
shashirao
Another thought came to mind - would a different pre-amp make more sense - especially the ones with variable EQ - Jazz or Revelation?
I own the Revelation C - however that is a MC pre-amp and may not work with the Ortofon 2M 78 cartridge.
Chris Firth
Not a good idea! Way too much gain. |
