New Posts New Posts RSS Feed - Groove Runner Turntable Speed Control
 Post Reply Post Reply Page  <1 456
Ernie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ernie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 11:37pm
Understood Graham,
Hope you don’t think I was criticising your work. Rega have obviously done a lot of work on their passive supply to get the best out of this motor and fair play to them.
I wonder what the scope would show with the Rega circuit (or the other circuits for that matter) connect to the mains supply.
Btw just notice the scope readings show the frequency to 4 decimal places all zeros. You certainly go to some lengths for us don’t you!
Pushing the boundaries
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 2:06am
Ahha, the scope and its decimal places... wishful thinking but it will go no lower than 10Hz resolution. But my AP is a different story:
I didn't think you were criticising my work. It's only right that I should be questioned or nobody will ever learn anything from these posts and topics. It's good for understanding what things do.
I don't pretend to have exhausted every possible measurement simply because in my mind electronics aren't as exact as some would like to believe. But then again I suppose I take some things to their extremes... Ermm
As an example, I'll be hopping over to the 70s amp topic shortly because I'm not satisfied with the power amp quite yet. The bugger is keeping me awake AngryWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 2:56am
Those of us who have been here awhile know that we will be satisfied when you feel satisfied enough to put your name on your latest design(s). They always sound and work the best.
Edited by BAK - 12 Oct 2018 at 2:57am
Enjoy Life Your Way!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 10:45pm
I wonder if it would work with a mark one or two GyroDec with the original ac motor. Do you want to borrow my Papst ac motor to try it out with the Groove Runner Graham?
"It would be good to see some spec's. It obviously runs on 230V but might not on 110V. What size phasing capacitor, and are there any other components? And is there a power rating on it?"
Jon: Next week I will dig the motor pod out and check the capacitor value. I know the Rega TT PSU's BD139/140 outputs got quite hot even with clip-on heatsinks i.e. it couldn't supply the current for the Papst motor.
"PS. would it be possible to press one of the known motors above into service on it?
Jon: I considered that and was considering a Premotec motor with the phase adjustment to minimise vibration. Then I started to look at DC motors and went that way.
