Interconnects for Solo Ultra-Linear |
Post Reply |
j633295
New Member Joined: 16 Apr 2010 Location: Surrey Status: Offline Points: 29 |
Posted: 12 May 2010 at 3:09pm |
Just ordered the Solo Ultra-Linear but now need to look for a pair of
Interconnects to connect a DAC to the Solo.
Any recommendations for under £150 would be welcome please. From a newbie Edited by j633295 - 12 May 2010 at 3:09pm |
Cyreg
Moderator Group Joined: 15 Jan 2008 Location: Netherlands Status: Offline Points: 313 |
Hi, might I suggest a GrahamSlee CuSat50?
Or can't it be a stereo RCA type
Edited by Cyreg - 12 May 2010 at 4:37pm |
TecnoDec/RB250/MP110>GramAmp2C/PSU1; Cyrus CD8SE; Cyrus FM7 > Exposure XXXV > Harbeth C7ES-3 '35th Anniversary'
cabling: IC 3x DNM V3; LScable Exposure DMF-two; Furu TP60 + MWaY and AH! powercords |
j633295
I am thinking of getting a pair of second hand 1m Nordost Red Dawn (£100) or the Van Den Hul D-102 MKIII. Which would be a better match for the Solo?
I unerstand that Nordost Red Dawn has brighter sounding whilst Van Den Hul D-102 MKIII is less so with mellow sound stage. Edited by j633295 - 14 May 2010 at 11:50am |
tg [RIP]
Moderator Group Joined: 19 Jan 2008 Location: Sydney Status: Offline Points: 1866 |
If you choose either of those cables be aware of a couple of things - a/ - the Red Dawn are unshielded and may be subject to pickup of noise/RFI etc, b/ - many of the VDH D-102 sold cheaply on ebay are not factory terminated, they have been bought as bulk cable and terminated by the seller or another third-party. The quality of this work may or may not be up to standard. What sound characteristics you will identify and prefer is very dependent on your other equipment, music tastes and personal preferences. Changing headphones will make a much bigger difference. If you want to hear the amp as the designer heard it then use the cable the designer used. There are good quality, shielded, cables, available from a number of sources relatively inexpensively if you prefer not to use the Cusat, it would be improper for me to recommend or suggest them here, perhaps check a few other forums for ideas. Graham has also published, at one time, articles on DIY cables from inexpensive materials, these have received favourable report from those who have made them. |
j633295
Yes I have been converted to the Graham Slee Klan yet again!
Just ordered the Cusat50 1.5 metre ( 1+ 1 separates) direct from Graham - can't wait! Graham, will I receive them early next week please? |
j633295
Does anyone know how long would it take to "burn-in" the Cusat50?
mrarroyo
Moderator Group Joined: 28 Jul 2008 Location: Miami Beach, FL Status: Offline Points: 1401 |
0 hours to 200 hours, depends who you ask.
Post Reply | |
