So which turntable? |
Post Reply | Page 123 6> |
vinyljunki
Regular Joined: 15 Feb 2016 Status: Offline Points: 52 |
Posted: 18 Feb 2021 at 9:00pm |
Ive been looking around at what "the best" turntable is for around £4000. Yes I understand best is very subjective...however
Interestingly, the Rega P10 gets rave press reviews but gets put down quite a bit (by possibly people that havent heard one) by turntable enthusiasts as "its just a Rega" Yes Rega do have a bit of a stigma as a budget company (I have owned a planar 3 myself for nearly 30 years, although it very modified) but does the P10 deserve to be cold shouldered by the VPI, Clearaudio, L*nn etc crowd? Any thoughts from owners or anyone that has had the chance to demo? Yes I will get to demo a few when lockdown rules change. Im looking for a bit of a shortlist....and yes the P10 is on it :-) Thanks Bill
CageyH
Senior Member Joined: 30 Apr 2012 Location: Toulouse, Franc Status: Offline Points: 1678 |
Thanks(1)
£4K will give you a pretty big choice.
Good luck with the search...
vinyljunki
Probably too much choice and will be difficult to get to listen to them all. I know the L*nn LP12 is in the price bracket but its the basic model. Having never heard a L*nn I can imagine it to be a lush laidback sounding deck but could be wrong. I would want a bit of life but not sterile....as I play lots of Jazz to underground Techno (yes I am one of those) So the P10 could be what I need, however the list could comprise of... Clearaudio Performance DC with Tracer arm VPI Prime Scout Gold Note Giglio Bryston BLP-1 Thorens TD 1601 It may even turn out im happy with my modded planar 3 and save myself a lot of cash lol |
ICL1P
Senior Member Joined: 04 Aug 2012 Location: Faringdon, Oxon Status: Online Points: 2341 |
Thanks(1)
Suggs
Moderator Group Joined: 07 Oct 2011 Location: France Status: Offline Points: 513 |
Thanks(1)
I would go for the best that you can afford from the Origin Live line, both their turntables and arms offer exceptional value for money and easily compete with models costing way more from other manufacturers IMO. Their performance is exactly what you want judging from your description of the sound that you like
patientot
Senior Member Joined: 28 Nov 2018 Location: USA Status: Offline Points: 1523 |
Thanks(1)
No real recommendation. I'll just say I wouldn't spend that amount of money on anything without being able to at least demo it first.
One thing I would consider is the practical operation of the turntable and whether certain things about it would annoy you. I know a couple of people that have dumped very fiddly turntables because they had quirks that simply became too annoying in their environment over time.
Oblongus
Regular Joined: 18 Feb 2021 Status: Offline Points: 54 |
Thanks(1)
Yeah, I think Rega are unfairly maligned as just a 'plug n play' manufacturer. I know their unwilligness to include VTA adjustment gets up the noses of those who think it's critical and think TT's should be infinitely tweakable. But I think they're impeccably engineered, it just depends whether you like what their low-mass design philosophy gives you - fast, detailed presentation, tending towards the lean. I don't wide experience to speak authoritatively but I'd second the recommendation of Origin Live, but I think you'll find it hard to find a complete dud at your budget. |
