New Posts New Posts RSS Feed - Solo SRGII Question
Solo SRGII Question
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Solo SRGII Question
    Posted: 10 Jul 2019 at 8:23pm
Will the Solo SRGII manage well driving AKG K701? I understand the K701 is a bit 'tough' to drive etc.
Thanks.
S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:39pm
Hi Shane, your understanding is correct - it is tough to drive (but it isn't the power) and I've always found it harsh in the highs and upper mids. The Solo Ultra-Linear DE sounds a lot better with the K701 than does the SRGII (in my opinion).
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:45pm
The 701 are revealing headphones for sure! I also own some lovely Sennheiser HD650. The latter gives a warmer tone.
Is the Solo SRGII more brighter sounding than the Ultra-Linear DE?
S.
Edited by southall-1998 - 10 Jul 2019 at 8:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 8:53pm
I'd say more "solid-state" rather than bright.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 9:00pm
Can easily imagine HD650 getting on well with the SRGII.
S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 10:45pm
The HD650 isn't a particularly high fidelity headphone. I would suggest selecting something else if you want to get the most out of the Solo.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 11:40pm
List some headphones that partner well with the Solo.
S.
This page was generated in 0.141 seconds.
