which one??? |
Post Reply | Page 12> |
SiE
New Member Joined: 30 Nov 2017 Location: Bristol, UK Status: Offline Points: 15 |
Posted: 30 Nov 2017 at 3:11pm |
After years of happily listening to my music via Apple Play, I'm putting together another vinyl front end. At the moment, I've got as far as the turntable (an SME model 10) and the arm (an Audiomod classic 2) and cartridges I already own are: Shure V15 3s, Denon moving coil and Goldring 1042. I would like to buy a Graham Slee phono stage on the basis that they seem excellent value for money, well reviewed and capable of performing at a level that matches the other pieces in the front end, however, I'm at a loss to know which of the many GS phono stages to choose - any advice?
morris_minor
Moderator Group Joined: 27 Mar 2012 Location: Surrey Status: Offline Points: 6015 |
Welcome to the forum, Simon!
The short answer to you question is "the best you can afford/want to spend"! Those cartridges in an Audiomods arm on an SME 10 (I'm drooling already!) demand the best. You probably know this forum operates a loan scheme - borrow an Accession and you won't want to send it back. And is that a low output Denon MC? Borrow an Elevator step-up amp to go with it. Drop a PM to Jon (aka Fatmangolf) to arrange of loan of whichever kit you'd like to try (and interconnects too). I'm sure you'll be thrilled at the sound coming from your records . . .
Tip: to send Fatmangolf a PM find one of his posts and click the drop-down menu to the right of his username then click Send Private Message.
Hi Simon, I'm ready to help when you contact me by PM.
Bob's recommendation is a good one and would be a lifetime investment. I run that combination of units and it brings my records to life via my Transfiguration Phoenix on modified arm SME IV and Michell Gorbe deck. |
SiE
Thanks, guys - all very encouraging! I've kind-of got the ball rolling by buying a "previously loved" Gram Amp 2 Communicator. I understand this was one of the earlier designs that went some way to setting the standard of GS's value for money phono amps which will give me a good idea of what's possible at the entry level. In the past, I've used on-board phono stages from Naim and Quad and, most successfully, following a recommendation from my dear old chum Umit Kayacan, a large Avi integrated amp, which he pointed out, had a lovely phono stage in it.
From what folk have already said, I can expect a decent dedicated phono stage to be a step up from this starting point.
Later on, the loan scheme can give me access to higher-end options so I can explore what's possible - how exciting! I'm glad I joined! |
DTB
New Member Joined: 30 Jan 2018 Status: Offline Points: 1 |
Greetings GSP Forum!
I just signed up today and would appreciate some advice. I have never had an outboard phono stage but have read numerous times that they are (usually) superior to integrated and think I should finally look into. I should say I like what I have at the moment but think that some greater detail and drive might work for me. My current system is a Systemdek IIX with a modfied Rega RB250 arm (Cardas rewire and Michell counterweight) and a Goldring 1042 MM cartridge / Roksan Kandy K2 integrated amp / Monitor Audio Silver 8 floorstanding speakers. My musical tastes include a range of rock and indie and some electronic music with occasional explorations of classical. In the scheme of things I am not sure where the Roksan Kandy phono stage sits and grateful for advice on what might be an improvement in quality i.e. would the Gram Amp 2 SE give a big leap in quality over the built in phono stage on the Kandy K2 or do I need to set my sights higher? Any feedback will be very greatly received.
BackinBlack
Welcome to the Forum Derek. The Gram Amp 2SE would certainly bring an improvement. Probably worth making use of the loan scheme to find out how much of an improvement. You might also try further up the range, perhaps the Reflex M, it's only going to cost you postage for the units. A PM to Jon, aka Fatmangolf will get things underway. A week or so of listening in your own home is really worth it. Happy Listening Ian |
