Accession phono stage review |
Post Reply | Page 123 14> |
morris_minor
Moderator Group Joined: 27 Mar 2012 Location: Surrey Status: Offline Points: 6017 |
Posted: 21 Oct 2015 at 8:47am |
Not so much a review (yet) since the Accession has only been powered up less than a day . . . .
But first impressions are - wow! What a stonking sound ! Music has a very tangible quality, and bass is deep but detailed and very well controlled. I'm noticing details in mixes that I hadn't before, too. It's being used with an Elevator and Zyx R100 - the dip switches being set to "off" (ie. up). The variable output works a treat with my ADC, and means the end of inline attenuators and phono t-pieces. Just set a mid-point gain level in the software, and the rotary output on the Accession can then be used to get the right input level for the best recording. Simple and very effective. More from me when the unit has burned in, and more albums have been put on the clock . . .
Chris Firth
Moderator Group Joined: 16 May 2013 Location: Rossendale, UK Status: Offline Points: 1532 |
Sounds like you're back in the saddle and well on the road to recovery.
Welcome back Bob |
Suggs
Moderator Group Joined: 07 Oct 2011 Location: France Status: Offline Points: 513 |
+1
morris_minor
Thanks, Chris and Derek! Having something good to focus on definitely aids recovery . . .
BAK
Senior Member Joined: 14 Mar 2010 Location: Kentucky, USA Status: Offline Points: 1744 |
Hang On To A Dream!
Music is my first love! |
miT
Senior Member Joined: 07 Jan 2009 Location: London Status: Offline Points: 890 |
Too right! Good to see your catching up with your homework before you start enjoying yourself Bob. |
Thanks Bob.
