New Posts New Posts RSS Feed - Connection between price and sound?
Eric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Quote  Post ReplyReply Direct Link To This Post Topic: Connection between price and sound?
    Posted: 09 Jul 2017 at 1:36pm
Mostly when it comes to hifi equipment there is connection between price and sound quality. Is it the same with GSP, or has the phono amps with higher prices more functions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 1:46pm
In my experiences price is related to performance though in part only. I have found many expensive items have not been very good over the last 40 years but good engineering doesn't always come cheap as with high equality components.
I can only commeny in the Era gold, revelation and Accession. Their are step gains in performance particularly in sound quality wit the accession.
Eric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 1:58pm
So if I would like to get max sound quality regardless of price I should go for Accession?
Right now my short list for testing is Accession and Reflex M. Any other suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 2:33pm
Connection is probably a good description rather than correlation. Trying both should at least confirm
In your mind the differences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 2:47pm
That should suffice.
Aussie Mick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aussie Mick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 4:03am
Agreed. Just the two.
RichW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichW Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 9:38am
Look no further.Wink
