CD Audio |
Post Reply | Page <1 5152535455> |
Author | ||
lfc jon
Senior Member Joined: 23 Jan 2018 Location: Devon Status: Offline Points: 3979 |
As soon as I got home from the charity shop I made sure both CDs played and then put them in the plastic sleeves I have so now they won't get scratched pulling them in & out of carboard.
Yes you'll enjoy the music for years to come. Interesting about the shop selling more cd's now.
lfc jon
I just thought I'd let you know.
Friday I go the Pr*- je** CD player, a CD Box DS3. As most of you know I was wanting a warmer sound from my CD playing, I've only let it burn in for just under a day and so far so good. I'm getting what I wanted and a bit more bass, the higher frequency are a lot less harsh too. I'm having a few problems with it as It won't read a CD first time, but on the 2nd time of loading it does, I'm going to see if this persists and if so I will contact the shop. I will see if this happens with the same CD in my old player first.
patientot
Senior Member Joined: 28 Nov 2018 Location: USA Status: Offline Points: 1523 |
Unless it's some sort of weird disc, that definitely shouldn't happen with any brand new CD player. Hopefully you get that issue resolved.
Chris Firth
Moderator Group Joined: 16 May 2013 Location: Rossendale, UK Status: Offline Points: 1529 |
I agree with patientot - ordinary CDs should not have any issues being read, and if the player is having problems reading discs I suggest taking it back to the place you got it from.
lfc jon
Just this min after your post I loaded another CD and it read It OK, but I will see if it persists. This CD player only plays RED BOOK CDs, not a problem for me as I don't have any SACDs and if I did or had CD-R or RW I can alwaya play them on my old player as I am keeping it just in case I do decide to get into computer audio, that's a big if mind you. but you never know!!
Chris Firth
If you had SACD discs the likelihood is they'd be hybrid discs, so the CD layer should play without issue.
