CD Audio |
Post Reply | Page <1 1819202122 55> |
lfc jon
Senior Member Joined: 23 Jan 2018 Location: Devon Status: Offline Points: 3986 |
Thanks(2)
I have given up on EAC and now am trying out on 21 day free trial of dBPoweramp and I'm already getting on with it, It's a lot easer to use than EAC (for me) and I like the art work you get with the file that will make finding it a lot easer (again for me) you can probably get that with EAC but on dBPoweramp it comes as default. I am still not sure where computer audio is for me but you never know?
For the price I think dBPoweramp is worth it even if it's only because of easer of use. I have been side tracked a bit as I have just got a new pair of Cusat50 cables and have been comparing them with my old cables listening with headphones and speakers AND I like what I been hearing, So tomorrow I will be doing a lot more ripping with dBpoweramp and finding out a bit more about it.
BackinBlack
Thanks(1)
Jon, glad to hear you seem to be making progress with dBPoweramp.
RichW
Senior Member Joined: 21 Jan 2013 Location: UK Status: Offline Points: 1471 |
Thanks(1)
Another thumbs-up here for dBPoweramp CD ripper. Very easy to use.
The art work download & CRC file checking are very handy. I've had the odd occasion where it doesn't find the correct album artwork but this is quite rare. |
lfc jon
This ReplayGain DSP. What is it and what does it do? Is it the box down on the left? I have just had my 1st CD where it could not get any Data, but found it easy to put in Artist and album title another plus point for this ripping software
patientot
Senior Member Joined: 28 Nov 2018 Location: USA Status: Offline Points: 1525 |
Replay Gain is a method of adjusting volume. I would recommend leaving that alone and not using it during the ripping process. If you decide later you need to apply RG tags, you can do that within a playback software program like Foobar2000 or a similar program. For ripping you don't need it, and it will only complicate things for you. dBPower actually has multiple ways of retrieving data for albums. If you load a CD, and it doesn't find anything, you can select another method from the menu and see if that does the trick. If nothing works, you can add the information automatically after the rip is done. The way I do that is by using a free program called MP3Tag. I don't use it often, but it works great for when I need it. |
TheScorpionsTale
Senior Member Joined: 02 Jan 2021 Location: Oxfordshire, UK Status: Offline Points: 318 |
Thanks(1)
I use it's Linux cousin, Puddletag. I'd be lost without it.
SL1200 II with SME M2-9R and various carts / Revelation M with PSU-1 / Cyrus amp, CD and streamer / Kralk Audio BC30-3 Floorstanders / Bitzie and Lautus USB |
lfc jon
I have made a short list of external SSD but can't make up my mind which one to go for?
List is - SanDisk Extreme V2, Western Digital My Passport (these are my preferred choice as I have had these brands before and found them vary reliable) Samsung T5 and T7. I am not interested in the security side of things as I'm only going to use them for music. Any thoughts on which one to go for or is there any other suggestions I should put on my list? One more thing, I like the idea of SSD being a portable one as I can take my music with me when out and about ie going to someone's home, this is the reason for not wonting security as I would need to load software to another computer to play my music (that's how I read it)
