HiFi System Components Ltd
Buzz troubleshooting help |
Post Reply ![]() |
HDave ![]() New Member ![]() ![]() Joined: 12 Nov 2020 Location: Canada Status: Offline Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Nov 2020 at 3:37pm |
Hi
I purchased used a Reflex Era Gold and and Elevator EXP. My system has power filters and was dead quite with the system turned on and no source running Day one I switched my old phono stage out for the Reflex and heard a definite improvement in sound on my MM Day 2 my new turntable with MC was installed and I added the Elevator. There was an audible noise a buzzing introduced into the system. I checked all the grounds and things were fine. The units were sitting on top of my Streamer. When the stream was turned on the buzz got much louder. I relocated the units away from all other equipment and the buzz diminished but it's still there. Not super audible but I can hear it from a couple of feet away. Is it because my units are likely a bit older and something like a transistor is deteriorating? Is it something the happens with MC in the system (my first ever MC so I have no idea). Suggestions? Thoughts appreciated |
Graham Slee ![]() Admin Group ![]() ![]() Telling it as it is Joined: 11 Jan 2008 Location: South Yorkshire Status: Offline Points: 9944 |
Thanks Admin Group. Oddly I just tried it to see if it was off with the TT power supply turned off as all of the other bases had already been covered. Nothing, no noise. Then I turned on the power supply and still nothing. I started the TT in motion and still no noise. It's some kind of Gremlin which is now gone. Could it have been a run in time thing? I know the units had not been used in a while
Fatmangolf ![]() Admin Group ![]() ![]() Joined: 23 Dec 2009 Location: Middlesbrough Status: Offline Points: 5653 |
Well done. It may have just needed a restart!
I'd still be cautious
Still be cautious? Can you elaborate?
I'm always suspicious about things fixing themselves, and problems sometimes come back to haunt us. So best to be ready in case the problem returns and to investigate further.
Post Reply ![]() |
