Battery based power source ? |
Post Reply |
mhamilton
New Member Joined: 24 Sep 2019 Location: California Status: Offline Points: 43 |
Thanks(2)
Posted: 09 Oct 2019 at 4:16pm |
Has there been discussion of a battery based power source for the phono preamps? There are several on the market. A couple of gel-cells should provide clean low noise 24V.
Thanks(2)
There has been talk about this on the forum and using the advanced search facility you might dig up some posts.
My own view is that batteries don't have a stable dissipation factor over the frequency range of operation: gain bandwidth refers to any frequency where the gain is 1 or above, and most products will go to at least 3 or 4 MHz. I am not talking about frequency response. The signal becomes part of the current being supplied by a power supply, and to comply with the laws of physics current flows in circles, and as such must flow back from ground through the power supply. Therefore the signal encounters the power source, and if it were to represent different conditions at different frequencies it might well have a subjective effect on the music. That was the thinking behind the Enigma version of the PSU1 (to make it more constant). If you have hum due to the way your system is connected to the mains supply, a battery supply to a phono stage might affect a cure by breaking a hum-loop, but it isn't because the power supply is causing it. If that were the case I don't think we'd still be selling phono stages after 20 years. Edited by Graham Slee - 09 Oct 2019 at 5:04pm |
patientot
Senior Member Joined: 28 Nov 2018 Location: USA Status: Online Points: 1525 |
I've seen battery powered phono stages on the market and people adapting their phono stages and other gear to run off battery power. I've often wondered if they don't trade one problem for another. Of course this is outside of my wheelhouse and above my pay grade as they say.
One design I looked at used a lithium ion rechargeable battery pack. At some point, the charge pack would wear out and have to be replaced. Another design by another company used several "D" cell alkaline batteries. Those will of course drain over time and have to be tossed - not something I like. I should also mention this company no longer offers that battery model and has since switched over to a similar model that uses conventional AC power.
Drewan77
Thanks(2)
Graham may recall that several years ago I showed him & John a dual 12v battery cell that I used to keep my Reflex M powered up when I transported it to other systems. It can also run a GSP phono stage for several hours.
I used it a few times and compared with the PSU-1 on both Reflex M & Accession M and it does indeed have an effect on the music (as Graham notes above) - never as satisfying as with the mains powered PSU, rather sterile, less engaging sounding. I also found it useful to check polarity with mains connections on the PSU-1 given that + & - are wired correctly on the battery supply & only one orientation of the fig-8 lead gives a very similar presentation.
zyss
New Member Joined: 04 Nov 2013 Location: St. Petersburg Status: Offline Points: 28 |
Batteries are not the same. Some types have more noise than others. From what I have read, the NiCd batteries are the least noisy. They also keep their voltage well while discharging. I am going to build a battery pack of NiCd batteries to try with my Revelation M. Are there any guidelines for building a battery pack for audio applications, anything to keep in mind? I noted Graham's reply on this subject, and I doubt that a battery power supply would be superior to the Enigma (which I'll need to upgrade from my PSU-1). But sound perception is subjective, and I may like some change of sound (or not). I'll keep you infomed when ready.
Post Reply | |
