Any advice for first turntable? |
Post Reply | Page 123 12> |
Frostg
Senior Member Joined: 19 Feb 2012 Location: Down Under Status: Offline Points: 261 |
Posted: 26 Feb 2012 at 7:44am |
Hi as someone who has not seen vinly for 25 years and then only had very cheap stuff, can you recommend a turntable? I am thinking of something like a Rega RP3 (Technics 1200), or that sort of price range. If there is something second hand also interested in advice. Plan to link to solo UL and Am thinking of the reflex, but once again any advice would be appreciated for a newbie! And as a double check, I am assuming something like this would give me better sound that a CD player and CD!
Also should I be looking at MM or MC. I understand a lot is personal preference but some pointers would be very helpful! Thanks in advance for any help. |
tg [RIP]
Moderator Group Joined: 19 Jan 2008 Location: Sydney Status: Offline Points: 1866 |
Either of those two tables should give you a more than satisfactory experience. I would perhaps tend toward the SL 1200 more than the Rega (though I own both a hot-rod Rega and an SL 1200) - the operational convenience and ease of cartridge change, along with the solidity of build of the Technics all count in its favour. There is a thread here with a few tweaks that are worth doing to the Technics. I am a Denon fan and can recommend the DL-110 HOMC for use with the Reflex M and the 1200. There are a good number of MM cartridges that will work well with this table, the Goldring 1042 receives good reports as also the Stanton 681 (if you can find one), the AT-95, 120 and 150MLX. Any of the above cartridges will give a good performance, some an exceptional one and none should be over $500, the AT-95 can be had for $50 and the 120 not a lot more. As to whether this would better the sound from a CD player depends in part on the CD player in question and in part on how well set up the cartridge and table are and how well cleaned your records are - there is a little more to it than closing the tray and pressing play For myself, I would prefer to listen to records generally, despite having several reasonable CD players. Hope this is some help. |
Technics 1200 is a no brainer apart from the fact that Panasonic must have lost their brains by discontinuing it...
Far better than my RP3 especially using a Goldring 1042. |
Frostg
Thanks for the advice, looks like I have some hunting to do. Also any thoughts on ORIGIN LIVE Aurora turntable in comparison? Thanks again.
Frostg
Is there anything I should watch out for when looking for the technics 1200, as assume it will be second hand?
And we are talking about MM rather than MC? Edited by Frostg - 26 Feb 2012 at 9:34pm |
I'm sorry, I can't talk about it - I am still in mourning I'm a giving sort of guy and I can't believe the heartless big business execs would murder such friends as the Technics SL1200 and Sennheiser HD250II - you need to be sitting here where I am with a Technics SL1200 sporting a 1042 (MM cart) playing into "some preamplification" on my test rack into a pair of HD250II's. It's the closest thing to heaven on earth! I cannot believe the heartlessness of those execs and all those merciless hit-men in forum land. Breadfans! It is literally the end of the world! |
Welcome back to vinyl and hello to you Frostg.
Having owned and upgraded an Rega P3-24 and a 1210 mk2, I too would spend £400+ on a second hand SL1200/1210 (silver or black versions) mark 2 (£150-200) and a decent MM cartridge like the Goldring 1042 (£200+). You will need a decent phono preamp, of course... Once over on an SL1200/1210 Check the arm isn't bent and it seems to move smoothly across the record. Check the headshell fits. Plug in and check it operates i.e. speed controls and strobe. Check it spins normally and quietly, and keeps its speed with slight finger friction. Check for any cracks in the metal top/chassis. Ask to take the metal platter off and check the muck underneath, especially anything metallic stuck to the magnets. It's heavy but unplug, shake and listen for rattles. Ideally play a record, otherwise plug into an amp with a phono input and set the volume low then listen for hum, then carefully touching the red (R+) connector on the cartridge followed by the white (L+) - both should hum briefly, otherwise the arm wiring is damaged. Read up a bit on alignment (how to fit the cartiridge correctly in the headshell) and you'll be glad you did. There's a very good Technics alignment protractor with instructions on Vinyl Engine. Perhaps I am getting a bit ahead here, but I think we are all looking forward to sharing your ecstatic posting about how great records sound! Best wishes Jon
Edited by Fatmangolf - 26 Feb 2012 at 11:20pm |
