 Post Reply Post Reply Page  <1 567
Pushpaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pushpaw Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 1:09am
Originally posted by mdnicke2 mdnicke2 wrote:
I (and my wallet) do appreciate knowing that going down the rabbit hole to chase the dragon is a common occurrence. One reason I’m looking into Graham Slee is I do want “endgame” pieces for a reasonable price.
I second this. And it's actually kind of comforting to know that Ash spent so much time seeking out the ideal sound in headphones and speakers and uses all GS products to do so.
P******t Debut Carbon, Goldring 1042, GS Accession MM w/Enigma, GS Solo ULDE w/PSU1, Sennheiser HD6XX, Technics SU-800 IA, Castle Knight 1, PS Audio Ultimate Outlet, Lautus & CuSat50
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:03am
I use what gets the job done. GS products are trustworthy and reliable. I combined the expertise of different specialists to get the best result I could. I am still refining but I am most of the way there already.
Lautus S/PDIF>Majestic>Lautus-R3>2xProprius>MySphere 3.1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pushpaw Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 1:55am
well that’s scary. What will you do when you arrive at your destination?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:31am
Well I'm keeping the Majestic and will buy Enigma PSU1 for it soon. That is definitely finalised. I am pretty sure I will stay with Proprius for driving MySphere rather than buying Solo ULDE with Enigma PSU1. I could try a loan of ULDE with Enigma and Lautus interconnects but I think it will be a waste of money, as I highly doubt any improvement would be heard over the Proprius. Proprius are true dual-mono and can process both a balanced signal and an inverted signal, which Solo can't do. I think this is more significant than having a linear micro-signal power supply at the amp level. Having the Enigma at micro-signal level (Majestic circuitry) will improve the resolution carried forward for amplification. I could try Libran interconnects between Majestic and Proprius instead of my current Lautus-R3 but over short cable distances, I doubt the balanced Libran will be better than the unbalanced 1.5m inverted phase Lautus with its ferrites. Would be close I think but not conclusive. Might upgrade earpads on my MySphere to further improve low bass dB SPL. Then it is just my source to sort; I need to have a simple, dedicated, wired streamer with no fans and a dedicated linear low noise PSU to compliment the Enigma. I just want minimal excellence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 10:03am
https://www.youtube.com/watch?v=r1e2VhrDdBQ
Just putting this here so I don't lose it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 10:00pm
Now this, THIS, is why I spend so much money on high fidelity audio equipment!
