New Posts New Posts RSS Feed - Accessions volume control?
A REAL Hi-Fi Owners' Club Forum With REAL Members and a Loaner Program to Prove It!
A rule of fairness:
Eric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Quote  Post ReplyReply Direct Link To This Post Topic: Accessions volume control?
    Posted: 09 Sep 2017 at 8:49pm
Is the volume control in the Accession active or passive?
In other words, is there any gain behind the volume control?
Opus3 Continuo with Opus3 Cantus parallel tracking tone arm - ZYX R100 Fuji - Elevator EXP MC Step-up - Vacuum Tube Audio PH16 - Vacuum Tube Audio SP14 - April Music Eximus S1 - Magnepan 3.3/R
Pushing the boundaries
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 7:39am
No gain but it is buffered. Technically it is active, with a gain of 1. Geek
(1 times something is still something...)
There are only two things to stop you being a success in life and they're both called Google - Notions are not solutions!
Eric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 9:11am
I thought my preamp had a great sound, but then I tested to connect the Accession "direct" to my power amps. What happened?
The sound is amazing! How is this possible from this tiny little box?
The only thing I miss is the remote control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 9:20am
"Who's that gut lord marching, you should cut down on your porklife mate, get some exercise". Written by Alexander James, David Rowntree, Damon Albarn, Graham Coxon
Reflex M, CuSat50, Majestic DAC, a Proprius pair.
DaveG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 4:08pm
I had exactly the same experience (my integrated had the option to bypass the pre stage and just use the power amps  ... which got me thinking.
So I now use the fixed out into a Proprius pair. Stunning!
dsockel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsockel Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 4:56pm
Any reason NOT to have the volume maxed out if I am feeding an integrated amp?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 7:02pm
Only possible reason IMO would be a sensitive input on amp like an old tuner or tape in that could pverload. Otherwise full volume is fine.
Forum Software by Web Wiz Forums® version 11.10
Copyright ©2001-2017 Web Wiz Ltd.
This page was generated in 0.093 seconds.
